Upgrade Projects Hot fixes Problem??
kishi_g
Member Posts: 162
Recently I involved upgrade from 3.7 to Nav4.0 SP3. After Upgrading the project some hot fixes was came. In some codeunits are customised.
suppose if i import the Hotfixes the Forms & CodeUnits are not merged. it will replaced. For example In Codenit 80 some customisation is there. In hot fix also codeunit is there. In this case can i follow which procedure???
Thanks & Regards,
kishore.
Thanks & Regards,
kishore.
You'll need to manually merge those code changes into your database. There are tools out there for this. Personally I like Beyond Compare, and I've also heard Araxis Merge is a good one.0
Thanks for your replies.
Thansk a lot.
Thanks & Regards,
Kishore.0
- 329 Dynamics CRM
