Problem with Excel Export using Automation
alsol
Member Posts: 243
Hi there,
I made different excel export reports using the Excel Automation. Normally this works perfect, but today I tried to edit an existing report and received an error message "Library not found".
Interesting here is, that when I go to Globals, I can not find a DataType "Automation". But the report still run, I just can not edit it.
Is this a problem with the license or with the local Office installation?
I think it is your office installation maybe a lower or higher version to the object when it was compiled. Check if there are any local variables defined.
Albert0 -
Hello again,
I figured out why I could not use any datatype "Automation":
You need to have granule 1750 C/OCX in your Navision license. So it is not related to Excel Version.
Just in case that someone else has this problem.
Regards0
