After following the installation manual for Nav 4.03 for business analytics i got the error message ”there are no bustiness entities available. Please ensure that there is a company selected. Navision was running and company selected, and the notification server connects to the server so that should be fine.
I then found a article in the knowledge base on the partner source which said I should uninstall .netframework, then uninstall business notification, restart server, install business notification and then install the .net framework. But that can’t be done, when trying to install business notification prior to installing the .net framework I get the error Creation of NSInstallPath Registry Key failed. So I have to install the .netframework first and then business notification, and then it fails again. I have tried everything possible and still get the error there are no business entitites available, please ensure that there is a company selected in Navision.
I am running a SQL server 2005, sqlxml 4.0, nav 4.03 on a windows 2003 server.
help would be very much appreciated.- :shock:
Install all components if installing prerequistes on one machine.
Hope this helps, Carol
when i try ned from template and chooses one of the templates the error message comes..
in the eventviewer these messages comes up
Event Type: Error
Event Source: MetadataService
Event Category: None
Event ID: 0
Date: 28.11.2006
Time: 12:03:22
User: N/A
Computer: OSL-DYN01
Description:
Exception System.InvalidCastException: Specified cast is not valid.
at System.Runtime.InteropServices.Marshal.GetIDispatchForObjectNative(Object o, Boolean onlyInContext)
at System.Runtime.InteropServices.Marshal.GetIDispatchForObject(Object o)
at System.Runtime.InteropServices.DispatchWrapper..ctor(Object obj)
at System.RuntimeType.WrapArgsForInvokeCall(Object[] aArgs, Int32[] aWrapperTypes)
at System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData)
at Microsoft.BusinessSolutions.Integration.MetadataService.IMetadataConnectionpoints.ListXMLPorts(IXMLPortList& list)
at Microsoft.BusinessSolutions.Integration.MetadataService.MetadataProvider.GetListOfXMLPorts(IXMLPortList list) occured in GetListOfXMLPorts
For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
Event Type: Error
Event ID: 0
Date: 28.11.2006
Time: 12:03:22
User: N/A
Computer: OSL-DYN01
Description:
As for as I know, Business Notification is not run on SQL Server 2005.
I m a Consult
E-Mail: ibrahim@imaconsult.com
<?xml version ="1.0"?>
<configuration>
<startup>
<supportedRuntime version="v1.1.4322" />
</startup>
</configuration>
This file needs to be created in the Client folder.
regards
tobias
The error you encountered is probably because one or more of the following conditions are true:
• You do not have user rights on the computer that is running Microsoft SQL Server on which you tried to install the Business Notification functionality. Make sure the acccount you use has enough privileges.
• The version of Microsoft SQL Server 2000 Notification Services is incorrect. It should correspond with the version of SQL Server you installed previously.
• The Terminal Services service is enabled on the computer on which you tried to install the Business Notification functionality. It should be stopped.
• The Microsoft .NET Framework 2.0 and Microsoft SQL Server 2005 are installed on the computer.
Thanks &Good Luck,
cunny
MCP - MBS Navision
jle@naviworld.com
I am facing the same problem, what exactly you posted.
When I remove .NetFramework 2.0 and install BSN, it gives me the
error that"nsinstallpath registry key failed".
Have you found any solution on this. Please let me know
if there is any other way
Senior Consultan
Senior Consultan
Kindly help me to resolve this problem
Senior Consultan
