How to remove spacing between header and Body section-Report
sivaguru_ksr
Member Posts: 100
Hai,
please place a vertical line in section-header part of Report and then Place a Horizontal line in the section-Body part.You will Notice some Gap(Space) between the Vertical Line and Horizontal Line. how to remove this unwanted space(1mm) and Join vertical and horizontal Line similar to 'L'.
please help me to slove this problem.
Draw your horizontal line where about you need it. As very last thing mark its height to about 50. You can hardly touch it with your mouse anymore, but it will have moved itself to the position more or less touching your vertical line.
Sandra0 -
Thanks for your kind Reply .
I have reduced the height of Horizontal line to 40.Now it works fine.
Thanks Again0
- 333 Dynamics CRM
