Employee Portal - Updating existing web parts
kuju
Member, Microsoft Employee Posts: 62
I have a problem using Employee portal.
Everything seems to be set up well and when i use the employee portal i do not notice any errors. Data is transfered as it should be.
But I do have problems modifying existing web parts (eg. adding a new tab or adding new fields to existing tabs).
These modifications are not shown on the portal.
I tryed several things, restart NAS, restart IIS, nothing happens.
The strange thing is when i create a new web part they are directly shown directly perfect, but then again i'm not able to change my newly created WP.
Am i doing something wrong?
Do i have to do more than just adding the records in the EP granule?
I did install the EP in a VPC.
Looks familiar to someone?
K
K
Dynamics Rules!
I am not sure about employee portal, but when I update my website, I have to press CTRL+F5, before I can view the changes, as they are stored locally, and IE does not retrieve them.Analyst Developer with over 17 years Navision, Contract Status - Busy
Mobile: +44(0)7854 842801
Email: david.cox@adeptris.com
Twitter: https://twitter.com/Adeptris
Website: http://www.adeptris.com0 -
Nope ... doesn't work!
Changing a caption works but adding a field or a tabblad isn't possible...
Anybody?Dynamics Rules!0 -
found it with a tip from BlackTiger... ! (Thnx)
A webpart is created as a template in "web part request template".
eg. Group code : <Blanc>
Web request Code : ItemCard
When you link it to a "Group" NAV does not refer to the template but copies the template data to a new WP request
eg. Group code : Sales
Web request code : ItemCard
And if you change the Template version nothing happens in the copied version ... ](*,)Dynamics Rules!0
- 327 Dynamics CRM
