Problem on using Excel automation in C/AL
Cem_Karaer
Cem_Karaer Member Posts: 281
Here is the problem: I try to extract data from an Excel sheet by using Excel automation objects, namely Excel application object, worksheet object and range object. But when I encounter an empty cell on the sheet, value property of the range object returns nothing!! C/AL doesn't even execute an assignment statement. How can I handle this? I tried to find if there is any way to check that the return value is null, empty or something like it, I found no function for this.
Cem Karaer @ Pargesoft
Dynamics NAV Developer since 2005
  • kriki
    kriki Member, Moderator Posts: 9,129
    Check T370:"Excel Buffer". This table has some code in it to import/export data from/to Excel.
    Maybe you can use this to receive the information from Excel. Or maybe in the code in the table, you can find how to do it.
  • Saalek
    Saalek Member Posts: 181
    The problem is that Navision doesn't accept NULL values.
    Try using Variant variables.
    Variant1 := Excell......
    Thne, use Variant variable function to know wath type of data is
    if variant1.ISINTEGER THEN
    begin
    end;
    if variant1.ISTEXT then
    begin
    end;
    I had similar problen reading access databases and that was my problem solution
    Bye
  • Cem_Karaer
    Thank you for your help.
