Problem starting NAS for Employee Portal
VWohde
Member Posts: 13
I have tried to get Employee Portal to work for now 2 days but ended up
with always the same problem.
I have installed SharePoint Services SP2 on Windows Server 2003 Std.
with MSMQ and J#1.1 and all the EP components as described in the
Installation Guide from Navision. I have also done the needed
configuration in Navision, that means configuring the user for NAS, setting
up the request and reply queues and creating the back-end key pair.
But anytime I start the NAS I get the following warning in windows event viewer (I have it only in german, so I will try to translate it):
Event Type: 109
Event description: Problem with queue observation..
(original event in german: Problem mit der Warteschlangenüberwachung..)
SharePoint and Navision are running on the same PC, the Navision Server
is using native database.
I have tried to change the permissions on both the request and reply
queue and even gave full access rights to the groups everyone and
anonymous and the user NAS starts with but the error stays the same.
Please help! I´m getting really frustrated with this...
Event Type: 109
Try to reinstall MSMQ and check that you have proper lines in web.config related to MSMQ
With Best Regards,
Naimish DaveNaimish Dave
(Software Engineer)0 -
problem is solved. It was not MSMQ or web.config but thank you anyway. I just forgot the first \ in the configuration of the front end request and reply queues.
Now everything works fine.0 -
- 324 Dynamics CRM
