MS Project 2007 and NAV Import problem
sendoh
Member Posts: 207
Hi Guys,
I'm working on the MS Project Integration now and have some unconsistent problem, the code below is working fine before,but for some unknown reason i got some random error like, ("Could not invoke the member count","Could not invoke the tasks" and etc.) and sometimes it works fine.
i know this error comes out because i'm using the API of MSproject member and the description of the error is descriptive but i couldn't resolve this issue. is this a registry problem or unproper installation or what? please advise. Thanks.
Sendoh
mportMSProjFile(pPath : Text[400];pVisible : Boolean)
CLEAR(Task);
CLEAR(Tasks);
CLEAR(App);
IF ISCLEAR(App) THEN
CREATE(App);
LCtrTask := 0;
App.FileOpenEx(pPath);
Tasks := App.ActiveProject.Tasks;
FOR LCtrTask := 1 TO Tasks.Count DO BEGIN
Task := Tasks.Item(LCtrTask); //Row No.
WITH ProjMapping DO BEGIN
INIT;
"Task Name" := Task.Name;
Start := Task.Start;
Finish := Task.Finish;
Resource := Task.ResourceNames;
Duration := Finish - Start;
Milestone := Task.Milestone;
INSERT;
App.Visible := pVisible;
IF App.FileExit(0) THEN
CLEAR(App);
Sendoh
Sendoh
be smart before being a clever.
Hi Guys,
After some testing I found out that the error rise when there's an open MSProject file and when it first time I run the codeunit and when trying to run the codeunit in second time it works fine.. I think I missed something before this lineApp.FileOpenEx(pPath);
Please advise what I missed. Thanks in advance.
SendohSendoh
be smart before being a clever.0
- 326 Dynamics CRM
